Дата и час: 16 Ное 2026, 02:48
Кодове за грешки при диагностика
Мнение Кодове за грешки при диагностика
Кодове загрешки при диагностика:
P0010
"A" Camshaft Position Actuator Circuit / Open, Bank 1
P0011
"A" Camshaft Position - Timing Over-Advanced or System Performance, Bank 1
P0012
"A" Camshaft Position - Timing Over-Retarded, Bank 1
P0013
"B" Camshaft Position - Actuator Circuit / Open, Bank 1
P0014
"B" Camshaft Position - Timing Over-Advanced or System Performance, Bank 1
P0015
"B" Camshaft Position - Timing Over-Retarded, Bank 1
P0016
Crankshaft Position - Camshaft Position Correlation, Bank 1 Sensor A
P0017
Crankshaft Position - Camshaft Position Correlation, Bank 1 Sensor B
P0018
Crankshaft Position - Camshaft Position Correlation, Bank 2 Sensor A
P0019
Crankshaft Position - Camshaft Position Correlation, Bank 2 Sensor B
P0020
"A" Camshaft Position Actuator Circuit / Open, Bank 2
P0021
"A" Camshaft Position - Timing Over-Advanced or System Performance, Bank 2
P0022
"A" Camshaft Position - Timing Over-Retarded, Bank 2
P0023
"B" Camshaft Position - Actuator Circuit / Open, Bank 2
P0024
"B" Camshaft Position - Timing Over-Advanced or System Performance, Bank 2
P0025
B Camshaft Position - Timing Over-Retarded, Bank 2
P0030
HO2S Heater Control Circuit, Bank 1 Sensor 1
P0031
HO2S Heater Control Circuit Low, Bank 1 Sensor 1
P0032
HO2S Heater Control Circuit High, Bank 1 Sensor 1
P0036
HO2S Heater Control Circuit, Bank 1 Sensor 2
P0037
HO2S Heater Control Circuit Low, Bank 1 Sensor 2
P0038
HO2S Heater Control Circuit High, Bank 1 Sensor 2
P0040
O2 Sensor Signals Swapped, Bank 1 Sensor 1/Bank 2 Sensor 1
P0041
O2 Sensor Signals Swapped, Bank 1 Sensor 2/ Bank 2 Sensor 2
P0042
HO2S Heater Control Circuit, Bank 1 Sensor 3
P0043
HO2S Heater Control Circuit Low, Bank 1 Sensor 3
P0044
HO2S Heater Control Circuit High, Bank 1 Sensor 3
P0050
HO2S Heater Control Circuit, Bank 2 Sensor 1
P0051
HO2S Heater Control Circuit Low, Bank 2 Sensor 1
P0052
HO2S Heater Control Circuit High, Bank 2 Sensor 1
P0056
HO2S Heater Control Circuit, Bank 2 Sensor 2
P0057
HO2S Heater Control Circuit Low, Bank 2 Sensor 2
P0058
HO2S Heater Control Circuit High, Bank 2 Sensor 2
P0068
MAP/MAF - Throttle Position Correlation
P0087
Fuel Rail/System Pressure - Too Low
P0088
Fuel Rail/System Pressure - Too High
P0089
Fuel Pressure Regulator 1 Performance
P0097
Intake Air Temperature Sensor 2 Circuit Low
P0098
Intake Air Temperature Sensor 2 Circuit High
P0100
Mass or Volume Air Flow "A" Circuit
P0101
Mass or Volume Air Flow "A" Circuit Range/Performance
P0102
Mass or Volume Air Flow "A" Circuit Low
P0103
Mass or Volume Air Flow "A" Circuit High
P0105
Manifold Absolute Pressure/Barometric Pressure Circuit
P0106
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P0107
Manifold Absolute Pressure/Barometric Pressure Circuit Low
P0108
Manifold Absolute Pressure/Barometric Pressure Circuit High
P0112
Intake Air Temperature Sensor 1 Circuit Low
P0113
Intake Air Temperature Sensor 1 Circuit High
P0116
Engine Coolant Temperature Sensor 1 Circuit Range/Performance
P0117
Engine Coolant Temperature Sensor 1 Circuit Low
P0118
Engine Coolant Temperature Sensor 1 Circuit High
P0120
Throttle/Pedal Position Sensor/Switch "A" Circuit
P0121
Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122
Throttle/Pedal Position Sensor/Switch "A" Circuit Low
P0123
Throttle/Pedal Position Sensor/Switch "A" Circuit High
P0125
Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0130
O2 Sensor Circuit, Bank 1 Sensor 1
P0131
O2 Sensor Circuit Low Voltage, Bank 1 Sensor 1
P0132
O2 Sensor Circuit High Voltage, Bank 1 Sensor 1
P0133
O2 Sensor Circuit Slow Response, Bank 1 Sensor 1
P0134
O2 Sensor Circuit No Activity Detected, Bank 1 Sensor 1
P0135
O2 Sensor Heater Circuit, Bank 1 Sensor 1
P0136
O2 Sensor Circuit, Bank 1 Sensor 2
P0137
O2 Sensor Circuit Low Voltage, Bank 1 Sensor 2
P0138
O2 Sensor Circuit High Voltage, Bank 1 Sensor 2
P0139
O2 Sensor Circuit Slow Response, Bank 1 Sensor 2
P0140
O2 Sensor Circuit No Activity Detected, Bank 1 Sensor 2
P0141
O2 Sensor Heater Circuit, Bank 1 Sensor 2
P0142
O2 Sensor Circuit, Bank 1 Sensor 3
P0143
O2 Sensor Circuit Low Voltage, Bank 1 Sensor 3
P0144
O2 Sensor Circuit High Voltage, Bank 1 Sensor 3
P0145
O2 Sensor Circuit Slow Response, Bank 1 Sensor 3
P0146
O2 Sensor Circuit No Activity Detected, Bank 1 Sensor 3
P0147
O2 Sensor Heater Circuit, Bank 1 Sensor 3
P0150
O2 Sensor Circuit, Bank 2 Sensor 1
P0151
O2 Sensor Circuit Low Voltage, Bank 2 Sensor 1
P0152
O2 Sensor Circuit High Voltage, Bank 2 Sensor 1
P0153
O2 Sensor Circuit Slow Response, Bank 2 Sensor 1
P0154
O2 Sensor Circuit No Activity Detected, Bank 2 Sensor 1
P0155
O2 Sensor Heater Circuit, Bank 2 Sensor 1
P0156
O2 Sensor Circuit, Bank 2 Sensor 2
P0157
O2 Sensor Circuit Low Voltage, Bank 2 Sensor 2
P0158
O2 Sensor Circuit High Voltage, Bank 2 Sensor 2
P0159
O2 Sensor Circuit Slow Response, Bank 2 Sensor 2
P0160
O2 Sensor Circuit No Activity Detected, Bank 2 Sensor 2
P0161
O2 Sensor Heater Circuit, Bank 2 Sensor 2
P0169
Incorrect Fuel Composition
P0171
System Too Lean, Bank 1
P0172
System Too Rich, Bank 1
P0174
System Too Lean, Bank 2
P0175
System Too Rich, Bank 2
P0181
Fuel Temperature Sensor "A" Circuit Range/Performance
P0182
Fuel Temperature Sensor "A" Circuit Low
P0183
Fuel Temperature Sensor "A" Circuit High
P0188
Fuel Temperature Sensor "B" Circuit High
P0190
Fuel Rail Pressure Sensor "A" Circuit
P0192
Fuel Rail Pressure Sensor "A" Circuit Low
P0200
Injector Circuit/Open
P0201
Injector Circuit/Open - Cylinder 1
P0202
Injector Circuit/Open - Cylinder 2
P0203
Injector Circuit/Open - Cylinder 3
P0204
Injector Circuit/Open - Cylinder 4
P0205
Injector Circuit/Open - Cylinder 5
P0206
Injector Circuit/Open - Cylinder 6
P0207
Injector Circuit/Open - Cylinder 7
P0208
Injector Circuit/Open - Cylinder 8
P0209
Injector Circuit/Open - Cylinder 9
P0210
Injector Circuit/Open - Cylinder 10
P0211
Injector Circuit/Open - Cylinder 11
P0212
Injector Circuit/Open - Cylinder 12
P0216
Injector/Injection Timing Control Circuit
P0219
Engine Overspeed Condition
P0221
Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
P0222
Throttle/Pedal Position Sensor/Switch "B" Circuit Low
P0223
Throttle/Pedal Position Sensor/Switch "B" Circuit High
P0225
Throttle/Pedal Position Sensor/Switch "C" Circuit
P0226
Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance
P0227
Throttle/Pedal Position Sensor/Switch "C" Circuit Low
P0228
Throttle/Pedal Position Sensor/Switch "C" Circuit High
P0230
System Too Rich at Idle
P0234
Turbocharger/Supercharger Overboost Condition
P0236
Turbocharger/Supercharger Boost Sensor "A" Circuit Range/Performance
P0237
Turbocharger/Supercharger Boost Sensor "A" Circuit Low
P0238
Turbocharger/Supercharger Boost Sensor "A" Circuit High
P0240
Turbocharger/Supercharger Boost Sensor "B" Circuit Range/Performance
P0241
Turbocharger/Supercharger Boost Sensor "B" Circuit Low
P0242
Turbocharger/Supercharger Boost Sensor "B" Circuit High
P0243
Turbocharger/Supercharger Wastegate Solenoid "A"
P0245
Turbocharger/Supercharger Wastegate Solenoid "A" Low
P0246
Turbocharger/Supercharger Wastegate Solenoid "A" High
P0247
Turbocharger/Supercharger Wastegate Solenoid "B"
P0249
Turbocharger/Supercharger Wastegate Solenoid "B" Low
P0250
Turbocharger/Supercharger Wastegate Solenoid "B" High
P0251
Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
P0252
Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0261
Cylinder 1 Injector Circuit Low
P0262
Cylinder 1 Injector Circuit High
P0263
Cylinder 1 Contribution/Balance
P0264
Cylinder 2 Injector Circuit Low
P0265
Cylinder 2 Injector Circuit High
P0266
Cylinder 2 Contribution/Balance
P0267
Cylinder 3 Injector Circuit Low
P0268
Cylinder 3 Injector Circuit High
P0269
Cylinder 3 Contribution/Balance
P0270
Cylinder 4 Injector Circuit Low
P0271
Cylinder 4 Injector Circuit High
P0272
Cylinder 4 Contribution/Balance
P0273
Cylinder 5 Injector Circuit Low
P0274
Cylinder 5 Injector Circuit High
P0275
Cylinder 5 Contribution/Balance
P0276
Cylinder 6 Injector Circuit Low
P0277
Cylinder 6 Injector Circuit High
P0278
Cylinder 6 Contribution/Balance
P0279
Cylinder 7 Injector Circuit Low
P0280
Cylinder 7 Injector Circuit High
P0281
Cylinder 7 Contribution/Balance
P0282
Cylinder 8 Injector Circuit Low
P0283
Cylinder 8 Injector Circuit High
P0284
Cylinder 8 Contribution/Balance
P0285
Cylinder 9 Injector Circuit Low
P0286
Cylinder 9 Injector Circuit High
P0287
Cylinder 9 Contribution/Balance
P0288
Cylinder 10 Injector Circuit Low
P0289
Cylinder 10 Injector Circuit High
P0290
Cylinder 10 Contribution/Balance
P0291
Cylinder 11 Injector Circuit Low
P0292
Cylinder 11 Injector Circuit High
P0294
Cylinder 12 Injector Circuit Low
P0295
Cylinder 12 Injector Circuit High
P0299
Turbocharger/Supercharger Underboost Condition
P0300
Random/Multiple Cylinder Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0307
Cylinder 7 Misfire Detected
P0308
Cylinder 8 Misfire Detected
P0309
Cylinder 9 Misfire Detected
P0310
Cylinder 10 Misfire Detected
P0311
Cylinder 11 Misfire Detected
P0312
Cylinder 12 Misfire Detected
P0318
Rough Road Sensor "A" Signal Circuit
P0321
Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322
Ignition/Distributor Engine Speed Input Circuit No Signal
P0324
Knock Control System Error
P0327
Knock Sensor 1 Circuit Low Bank 1 or Single Sensor
P0328
Knock Sensor 1 Circuit High Bank 1 or Single Sensor
P0332
Knock Sensor 2 Circuit Low Bank 2
P0333
Knock Sensor 2 Circuit High Bank 2
P0340
Camshaft Position Sensor "A" Circuit, Bank 1 or Single Sensor
P0341
Camshaft Position Sensor "A" Circuit Range/Performance, Bank 1 or Single Sensor
P0342
Camshaft Position Sensor "A" Circuit Low, Bank 1 or Single Sensor
P0343
Camshaft Position Sensor "A" Circuit High, Bank 1 or Single Sensor
P0345
Camshaft Position Sensor "A" Circuit, Bank 2
P0346
Camshaft Position Sensor "A" Circuit Range/Performance, Bank 2
P0347
Camshaft Position Sensor "A" Circuit Low, Bank 2
P0348
Camshaft Position Sensor "A" Circuit High, Bank 2
P0351
Ignition Coil "A" Primary/Secondary Circuit
P0352
Ignition Coil "B" Primary/Secondary Circuit
P0353
Ignition Coil "C" Primary/Secondary Circuit
P0354
Ignition Coil "D" Primary/Secondary Circuit
P0355
Ignition Coil "E" Primary/Secondary Circuit
P0356
Ignition Coil "F" Primary/Secondary Circuit
P0357
Ignition Coil "G" Primary/Secondary Circuit
P0358
Ignition Coil "H" Primary/Secondary Circuit
P0359
Ignition Coil "I" Primary/Secondary Circuit
P0360
Ignition Coil "J" Primary/Secondary Circuit
P0361
Ignition Coil "K" Primary/Secondary Circuit
P0362
Ignition Coil "L" Primary/Secondary Circuit
P0365
Camshaft Position Sensor "B" Circuit, Bank 1
P0366
Camshaft Position Sensor "B" Circuit, Bank 1 Range/Performance
P0367
Camshaft Position Sensor "B" Circuit Low, Bank 1
P0368
Camshaft Position Sensor "B" Circuit High, Bank 1
P0380
Glow Plug/Heater Circuit "A"
P0381
Glow Plug/Heater Indicator Circuit
P0391
Camshaft Position Sensor "B" Circuit Range/Performance, Bank 2
P0392
Camshaft Position Sensor "B" Circuit Low, Bank 2
P0393
Camshaft Position Sensor "B" Circuit High, Bank 2
P0400
Exhaust Gas Recirculation Flow
P0401
Exhaust Gas Recirculation Flow Insufficient Detected
P0402
Exhaust Gas Recirculation Flow Excessive Detected
P0403
Exhaust Gas Recirculation Control Circuit
P0404
Exhaust Gas Recirculation Control Circuit Range/Performance
P0411
Secondary Air Injection System Incorrect Flow Detected
P0413
Secondary Air Injection System Switching Valve "A" Circuit Open
P0414
Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0416
Secondary Air Injection System Switching Valve "B" Circuit Open
P0417
Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418
Secondary Air Injection System Control "A" Circuit
P0420
Catalyst System Efficiency Below Threshold, Bank 1
P0421
Warm Up Catalyst Efficiency Below Threshold, Bank 1
P0422
Main Catalyst Efficiency Below Threshold, Bank 1
P0423
Heated Catalyst Efficiency Below Threshold, Bank 1
P0424
Heated Catalyst Temperature Below Threshold, Bank 1
P0425
Catalyst Temperature Sensor Circuit, Bank 1 Sensor 1
P0426
Catalyst Temperature Sensor Circuit Range/Performance, Bank 1 Sensor 1
P0427
Catalyst Temperature Sensor Circuit Low, Bank 1 Sensor 1
P0428
Catalyst Temperature Sensor Circuit High, Bank 1 Sensor 1
P0429
Catalyst Heater Control Circuit, Bank 1
P0430
Catalyst System Efficiency Below Threshold, Bank 2
P0431
Warm Up Catalyst Efficiency Below Threshold, Bank 2
P0432
Main Catalyst Efficiency Below Threshold, Bank 2
P0441
Evaporative Emission System Incorrect Purge Flow
P0442
Evaporative Emission System Leak Detected (small leak)
P0444
Evaporative Emission System Purge Control Valve Circuit Open
P0445
Evaporative Emission System Leak Detected (large leak)
P0449
Evaporative Emission System Vent Valve/Solenoid Circuit
P0455
P0456
Evaporative Emission System Leak Detected (very small leak)
P0458
Evaporative Emission System Purge Control Valve Circuit Low
P0459
Evaporative Emission System Purge Control Valve Circuit High
P0480
Fan 1 Control Circuit
P0481
Fan 2 Control Circuit
P0489
Exhaust Gas Recirculation Control Circuit Low
P0490
Exhaust Gas Recirculation Control Circuit High
P0491
Secondary Air Injection System Insufficient Flow, Bank 1
P0492
Secondary Air Injection System Insufficient Flow, Bank 2
P0498
Evaporative Emission System Vent Valve Control Circuit Low
P0499
Evaporative Emission System Vent Valve Control Circuit High
P0501
Vehicle Speed Sensor "A" Range/Performance
P0505
Idle Air Control System
P0506
Idle Air Control System RPM Lower Than Expected
P0507
Idle Air Control System RPM Higher Than Expected
P0510
Closed Throttle Position Switch
P0544
Exhaust Gas Temperature Sensor Circuit, Bank 1 Sensor 1
P0545
Exhaust Gas Temperature Sensor Circuit Low, Bank 1 Sensor 1
P0546
Exhaust Gas Temperature Sensor Circuit High, Bank 1 Sensor 1
P0562
System Voltage Low
P0563
System Voltage High
P0564
Cruise Control Multi-Function Input "A" Circuit
P0597
Thermostat Heater Control Circuit/Open
P0598
Thermostat Heater Control Circuit Low
P0599
Thermostat Heater Control Circuit High
P0600
Serial Communication Link
P0601
Internal Control Module Memory Check Sum Error
P0602
Control Module Programming Error
P0603
Internal Control Module Keep Alive Memory (KAM) Error
P0604
Internal Control Module Random Access Memory (RAM) Error
P0605
Internal Control Module Read Only Memory (ROM) Error
P0606
Control Module Processor
P0607
Control Module Performance
P0608
Control Module VSS Output "A"
P0609
Control Module VSS Output "B"
P0613
TCM Processor
P0614
ECM / TCM Incompatible
P0627
Fuel Pump "A" Control Circuit/Open
P0629
Fuel Pump "A" Control Circuit High
P0638
Throttle Actuator Control Range/Performance, Bank 1
P0639
Throttle Actuator Control Range/Performance, Bank 2
P0641
Sensor Reference Voltage "A" Circuit/Open
P0642
Sensor Reference Voltage "A" Circuit Low
P0643
Sensor Reference Voltage "A" Circuit High
P0651
Sensor Reference Voltage "B" Circuit/Open
P0652
Sensor Reference Voltage "B" Circuit Low
P0653
Sensor Reference Voltage "B" Circuit High
P0657
Actuator Supply Voltage "A" Circuit/Open
P0658
Actuator Supply Voltage "A" Circuit Low
P0659
Actuator Supply Voltage "A" Circuit High
P0670
Glow Plug Control Module Control Circuit/Open
P0671
Cylinder 1 Glow Plug Circuit/Open
P0672
Cylinder 2 Glow Plug Circuit/Open
P0673
Cylinder 3 Glow Plug Circuit/Open
P0674
Cylinder 4 Glow Plug Circuit/Open
P0675
Cylinder 5 Glow Plug Circuit/Open
P0676
Cylinder 6 Glow Plug Circuit/Open
P0677
Cylinder 7 Glow Plug Circuit/Open
P0678
Cylinder 8 Glow Plug Circuit/Open
P0679
Cylinder 9 Glow Plug Circuit/Open
P0680
Cylinder 10 Glow Plug Circuit/Open
P0684
Glow Plug Control Module to PCM Communication Circuit Range/Performance
P0685
ECM/PCM Power Relay Control Circuit/Open
P0686
ECM/PCM Power Relay Control Circuit Low
P0687
ECM/PCM Power Relay Control Circuit High
P0688
ECM/PCM Power Relay Sense Circuit/Open
P0691
Fan 1 Control Circuit Low
P0692
Fan 1 Control Circuit High
P0693
Fan 2 Control Circuit Low
P0694
Fan 2 Control Circuit High
P0697
Sensor Reference Voltage "C" Circuit/Open
P0698
Sensor Reference Voltage "C" Circuit Low
P0699
Sensor Reference Voltage "C" Circuit High
P0700
Transmission Control System (MIL Request)
P0701
Transmission Control System Range/Performance
P0702
Transmission Control System Electrical
P0704
Clutch Switch Input Circuit
P0705
Transmission Range Sensor "A" Circuit (PRNDL Input)
P0706
Transmission Range Sensor "A" Circuit Range/Performance
P0710
Transmission Fluid Temperature Sensor "A" Circuit
P0711
Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
P0712
Transmission Fluid Temperature Sensor "A" Circuit Low
P0713
Transmission Fluid Temperature Sensor "A" Circuit High
P0714
Transmission Fluid Temperature Sensor "A" Circuit Intermittent
P0715
Input/Turbine Speed Sensor "A" Circuit
P0716
Input/Turbine Speed Sensor "A" Circuit Range/Performance
P0717
Input/Turbine Speed Sensor "A" Circuit No Signal
P0720
Generator Control Circuit
P0721
Output Speed Sensor Circuit Range/Performance
P0722
Output Speed Sensor Circuit No Signal
P0725
P0726
P0727
P0729
Gear 6 Incorrect Ratio
P0730
Incorrect Gear Ratio
P0731
Gear 1 Incorrect Ratio
P0732
Gear 2 Incorrect Ratio
P0733
Gear 3 Incorrect Ratio
P0734
Gear 4 Incorrect Ratio
P0735
Gear 5 Incorrect Ratio
P0736
Reverse Incorrect Ratio
P0740
Torque Converter Clutch Circuit/Open
P0741
Torque Converter Clutch Circuit Performance/Stuck Off
P0743
Torque Converter Clutch Circuit Electrical
P0746
Pressure Control Solenoid "A" Performance/Stuck Off
P0747
Pressure Control Solenoid "A" Stuck On
P0748
Pressure Control Solenoid "A" Electrical
P0749
Pressure Control Solenoid "A" Intermittent
P0751
Shift Solenoid "A" Performance/Stuck Off
P0752
Shift Solenoid "A" Stuck On
P0753
Shift Solenoid "A" Electrical
P0756
Shift Solenoid "B" Performance/Stuck Off
P0757
Shift Solenoid "B" Stuck On
P0758
Shift Solenoid "B" Electrical
P0761
Shift Solenoid "C" Performance/Stuck Off
P0762
Shift Solenoid "C" Stuck On
P0763
Shift Solenoid "C" Electrical
P0766
Shift Solenoid "D" Performance/Stuck Off
P0768
Shift Solenoid "D" Electrical
P0771
Shift Solenoid "E" Performance/Stuck Off
P0773
Shift Solenoid "E" Electrical
P0776
Pressure Control Solenoid "B" Performance/Stuck Off
P0777
Pressure Control Solenoid "B" Stuck On
P0778
Pressure Control Solenoid "B" Electrical
P0779
Pressure Control Solenoid "B" Intermittent
P0780
Shift Error
P0781
1-2 Shift
P0782
2-3 Shift
P0783
3-4 Shift
P0784
4-5 Shift
P0785
Shift Timing Solenoid "A"
P0791
Intermediate Shaft Speed Sensor "A" Circuit
P0796
Pressure Control Solenoid "C" Performance/Stuck Off
P0797
Pressure Control Solenoid "C" Stuck On
P0798
Pressure Control Solenoid "C" Electrical
P0799
Pressure Control Solenoid "C" Intermittent
P0811
Excessive Clutch "A" Slippage
P0820
Gear Lever X-Y Position Sensor Circuit
P0821
Gear Lever X Position Circuit
P0822
Gear Lever Y Position Circuit
P0829
5-6 Shift
P0838
Four Wheel Drive (4WD) Switch Circuit Low
P0840
Transmission Fluid Pressure Sensor/Switch "A" Circuit
P0841
Transmission Fluid Pressure Sensor/Switch "A" Circuit Range/Performance
P0842
Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
P0845
Transmission Fluid Pressure Sensor/Switch "B" Circuit
P0846
Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
P0863
TCM Communication Circuit
P0864
TCM Communication Circuit Range/Performance
P0865
TCM Communication Circuit Low
P0884
TCM Power Input Signal Intermittent
P0886
TCM Power Relay Control Circuit Low
P0887
TCM Power Relay Control Circuit High
P0889
TCM Power Relay Sense Circuit Range/Performance
P0890
TCM Power Relay Sense Circuit Low
P0891
TCM Power Relay Sense Circuit High
P0892
TCM Power Relay Sense Circuit Intermittent
P0914
Gear Shift Position Circuit
P0915
Gear Shift Position Circuit Range/Performance
P0918
Gear Shift Position Circuit Intermittent
P0919
Gear Shift Position Control Error
P0929
Gear Shift Lock Solenoid Control Circuit Range/Performance
P1009
Air Mass Meter 1/2 Implausible Signal from Load Detection
P1026
Activation Intake Manifold Flap for Air Stream Regulation Short Circuit to B+
P1027
Activation Intake Manifold Flap for Air Stream Regulation Short Circuit to Ground (GND)
P1028
Activation Intake Manifold Flap for Air Stream Regulation Open Circuit
P1073
Mass Air Flow (MAF) Sensor 2 -G246- Signal Too Small
P1074
Mass Air Flow (MAF) Sensor 2 -G246- Signal Too Large
P1081
Exhaust-Bank3, Mixture Adaptation Range 1 Lower Lean Limit Not Reached
P1082
Exhaust-Bank3, Mixture Adaptation Range 2 Lower Lean Limit Not Reached
P1083
Exhaust-Bank3, Mixture Adaptation Range 1 Rich Limit Exceeded
P1084
Exhaust-Bank3, Mixture Adaptation Range 2 Rich Limit Exceeded
P1085
Exhaust-Bank4, Mixture Adaptation Range 1 Lower Lean Limit Not Reached
P1086
Exhaust-Bank4, Mixture Adaptation Range 2 Lower Lean Limit Not Reached
P1087
Exhaust-Bank4, Mixture Adaptation Range 1 Rich Limit Exceeded
P1088
Exhaust-Bank4, Mixture Adaptation Range 2 Rich Limit Exceeded
P1102
HO2S Heater Control Circuit (Bank 1 Sensor 1) High
P1103
Bank1-Probe1, Heating Circuit Output Too Low
P1105
HO2S Heater Control Circuit (Bank 1 Sensor 2) High
P1107
HO2S Heater Control Circuit (Bank 2 Sensor 1) High
P1110
HO2S Heater Control Circuit (Bank 2 Sensor 2) High
P1113
Bank1, Sensor 1 Internal Resistance Too Large
P1114
Bank 1, sensor 2 Internal resistance too large
P1115
HO2S Heater Control Circuit (Bank 1 Sensor 1) Low
P1116
P1117
HO2S Heater Control Circuit (Bank 1 Sensor 2) Low
P1118
P1127
Bank1, Mixture Adaption (mult.) System Too Rich
P1128
Bank1, Mixture Adaption (mult.) System Too Lean
P1129
Bank2, Mixture Adaption (mult.) System Too Rich
P1130
Bank2, Mixture Adaption (mult.) System Too Lean
P1136
Bank1, Mixture Adaption (add.) System Too Lean
P1137
Bank1, Mixture Adaption (add.) System Too Rich
P1138
Bank2, mixture adaption (add.) system too lean
P1139
Bank2, Mixture Adaption (add.) System Too Rich
P1141
Load Detection Implausible Value
P1142
Load Detection Value Below Lower Limit
P1143
Load Detection Value Above Upper Limit
P1144
Mass Air Flow (MAF) Sensor -G70- Open Circuit/Short Circuit to Ground (GND)
P1145
Mass Air Flow (MAF) Sensor -G70- Short Circuit to B+
P1146
Air Mass Meter -G70 Supply Voltage
P1151
Long Term Fuel Trim Additive Air., Area 1 System Too Lean
P1152
Long Term Fuel Trim Additive Air., Area 2 System Too Lean
P1155
Manifold Absolute Pressure (MAP) Sensor -G71- Short Circuit to B+
P1156
Manifold Absolute Pressure (MAP) Sensor -G71- Open Circuit/Short to Ground (GND)
P1157
P1160
Intake Air Temperature (IAT) Sensor -G72- Short Circuit to Ground (GND)
P1161
Intake Air Temperature (IAT) Sensor -G72- Open Circuit/Short Circuit to B+
P1162
Fuel Temperature Sensor A Circuit Low
P1163
Fuel Temperature Sensor A Circuit High
P1164
Fuel Temperature Sensor -G81- Unplausible Signal
P1165
Long Term Fuel Trim Additive Air., Area 1 System Too Rich
P1166
Long Term Fuel Trim Additive Air., Area 2 System Too Rich
P1167
Mass Air Flow (MAF) Sensor 2 -G246- Unplausible Signal
P1171
Angle Sender 2 for Throttle Valve Drive -G188 Implausible Signal
P1172
Angle Sender 2 for Throttle Valve Drive -G188 Signal Too Low
P1173
Angle sender 2 for throttle valve drive -G188 Signal Too High
P1174
Fuel Trim, Bank 1 Injection Timing Deviation
P1175
Pre-Injection Switched Off
P1176
Bank1, Lambda Correction Downstream of Catalyst Control Limit Reached
P1177
Bank2, Lambda Correction Downstream of Catalyst Control Limit Reached
P1196
O2 Sensor Heater Circuit, Bank1 Sensor1 Electrical Fault
P1197
O2 Sensor Heater Circuit, Bank2 Sensor1 Electrical Fault
P1198
O2 Sensor Heater Circuit, Bank1 Sensor2 Eletrical Fault
P1199
HO2S Heater Control Circuit, Bank2 Sensor2
P1213
P1214
P1215
P1216
P1217
Cylinder 5 Fuel Injector -N83- Short circuit to B+
P1218
Cylinder 6 Fuel Injector -N84- Short circuit to B+
P1225
P1226
P1227
P1228
P1229
Cylinder 5 Fuel Injector -N83- Short Circuit to Ground (GND)
P1230
Cylinder 6 Fuel Injector -N84- Short Circuit to Ground (GND)
P1237
Cylinder 1 Injector -N30 Open Circuit
P1238
Cylinder 2 Injector -N31 Open Circuit
P1239
Cylinder 3 Injector -N32 Open Circuit
P1240
Cylinder 4 Injector -N33 Open Circuit
P1241
Cylinder 5 Injector -N83 Open Circuit
P1242
Cylinder 6 Injector -N84 Open Circuit
P1245
Needle Lift Sensor -G80- Short Circuit to Ground (GND)
P1246
Needle Lift Sender -G80 Implausible Signal
P1247
Needle Lift Sensor -G80- Open Circuit/Short Circuit to B+
P1248
Injection Pump Fuel Metering Control (A) Range/Performance
P1250
Fuel Level Too Low
P1251
Cold Start Injector -N108- Short Circuit to B+
P1252
Cold Start Injector -N108- Open Circuit/Short Circuit to Ground GND)
P1255
Engine Coolant Temperature (ECT) Sensor -G62- Short Circuit to Ground
P1256
Engine Coolant Temperature (ECT) Sensor -G62- Open Circuit/Short Circuit to B+
P1280
Air Control Valve for Injectors -N212 Air Flow Too Low
P1296
Malfunction in Cooling System
P1300
Misfire Detected Low Fuel
P1321
Knock Sensor 3-G198 Signal Too Low
P1322
Knock Sensor 3-G198 Signal Too High
P1323
Knock Sensor 4-G199 Signal Too Low
P1324
Knock Sensor 4-G199 Signal Too High
P1335
Engine Torque Monitoring 2 Value Above Upper Control Limit
P1336
EngineTorque Monitoring Value Above Upper Control Limit
P1337
Bank1, Camshaft Position (CMP) =>Sensor -G40- Short Circuit to Ground (GND)
P1338
Bank 1, Camshaft Position (CMP) Sensor -G40- = > Open Circuit/Short Circuit to Ground (GND)
P1340
Camshaft Position Sensor-G40, Engine Speed Sensor-G28 Incorrect Allocation
P1341
Ignition Coil Power Output Stage 1 Short Circuit to Ground (GND)
P1343
Ignition Coil Power Output Stage 2 Short circuit to Ground (GND)
P1345
Ignition Coil Power Output Stage 3 Short Circuit to Ground (GND)
P1354
Modulating Piston Movement Sender -G149 Electrical Fault in Circuit
P1355
Ignition Activation Cylinder 1 Open Circuit
P1356
Ignition Activation Cylinder 1 Short Circuit to B+
P1357
Ignition Activation Cylinder 1 Short Circuit to Ground (GND)
P1358
Ignition Activation Cylinder 2 Open Circuit
P1359
Ignition Activation Cylinder 2 Short Circuit to B+
P1360
Ignition Activation Cylinder 2 Short Circuit to Ground (GND)
P1361
Ignition Activation Cylinder 3 Open Circuit
P1362
Ignition Activation Cylinder 3 Short Circuit to B+
P1363
Ignition Activation Cylinder 3 Short Circuit to Ground (GND)
P1364
Ignition Activation Cylinder 4 Open Circuit
P1365
Ignition Activation Cylinder 4 Short Circuit to B+
P1366
Ignition Activation Cylinder 4 Short Circuit to Ground (GND)
P1387
P1388
P1391
Bank2, Camshaft Position (CMP) =>Sensor 2 -G163- Short Circuit to Ground (GND)
P1392
Bank2, Camshaft Position (CMP) = >Sensor 2 -G163- Open Circuit/Short Circuit to B+
P1393
Ignition Output 1 Electrical Fault in Circuit
P1394
Ignition Output 2 Electrical Fault in Circuit
P1395
Ignition Output 3 Electrical Fault in Circuit
P1401
EGR Vacuum Regulator Solenoid Valve -N18- Short Circuit to Ground (GND)
P1402
EGR Vacuum Regulator Solenoid Valve -N18- Short Circuit to B+
P1407
Exhaust Gas Recirculatio Sensor (A) Circuit Low
P1408
Exhaust Gas Recirculatio Sensor (A) Circuit High
P1410
Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80- Short Circuit to B+
P1411
Bank2, Secondary Air System Air Flow Too Low
P1413
Pressure Sensor for Exhaust Gas Recirculation Signal Too High
P1414
Bank2, Secondary Air System Leak Detected
P1418
Fuel Level Sensor (A) Circuit High
P1420
Secondary Air Injection System Switching Valve (A) Circuit Malfunction
P1421
Secondary Air Injection (AIR) Solenoid Valve -N112- Short Circuit to Ground (GND)
P1422
Secondary Air Injection (AIR) Solenoid Valve -N112- Short Circuit to B+
P1424
Bank1, Secondary Air System Leak Detected
P1425
Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80- Short Circuit to Ground (GND)
P1426
Evaporative Emission System Pure Control Valve Circuit Open
P1432
Secondary Air Injection System Switching Valve (A) Circuit Open
P1433
Secondary Air Pump Relay-J299 Open Circuit
P1434
Secondary Air Injection (AIR) Pump Relay -J299- Short Circuit to B+
P1435
Secondary Air Injection (AIR) Pump Relay -J299- Short Circuit to Ground (GND)
P1437
Valve -2- for EGR -N213- Short Circuit to B+
P1438
Valve -2- for EGR -N213- Open Circuit/Short Circuit to Ground (GND)
P1440
Exhaust Gas Recirculation Valve -N18 Open Circuit
P1441
Exhaust Gas Recirculation Valve -N18- Open Circuit/Short Circuit to Ground (GND)
P1446
Temperature Sensor 1 for Catalyst -G20- Short Circuit to Ground (GND)
P1450
Secondary Air Injection System Short Circuit to B+
P1451
Secondary Air Injection System Short Circuit to Ground (GND)
P1452
Secondary Air System Open Circuit
P1467
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115- Short to B+
P1468
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115- Short to Ground
P1469
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115- Open
P1471
EVAP Emission Control LPD Circuit Short Circuit to B+
P1472
EVAP Emission Control LPD Circuit Short Circuit to Ground (GND)
P1473
Leak Diagnosis Pump - Tank Breather System Open Circuit
P1475
Leak Diagnosis Pump - Tank Breather System Malfunction/No Signal
P1476
Leak Diagnosis Pump - Tank Breather System Malfunction/Vacuum Too Low
P1477
P1482
Secondary Air Injection (AIR) Pump Relay 2 -J545- Short Circuit to B+
P1483
Secondary Air Injection (AIR) Pump Relay 2 -J545- Short Circuit to Ground (GND)
P1484
Secondary Air Injection (AIR) Pump Relay 2 -J545- Electrical Malfunction in Circuit
P1489
Evaporative Emission (EVAP) Canister Purge Regulator Valve 2 -N333- Short Circuit to B+
P1490
Evaporative Emission (EVAP) Canister Purge Regulator Valve 2 -N333- Short Circuit to Ground (GND)
P1491
Evaporative Emission (EVAP) Canister Purge Regulator Valve 2 -N333- Open Circuit
P1497
Secondary Air System, Bank 3 Flow Faulty
P1498
Secondary Air System, Bank 4 Flow Faulty
P1500
Fuel Pump Primary Circuit Fault in Electrical Circuit
P1501
Fuel Pump (FP) Relay -J17- Short Circuit to Ground (GND)
P1502
Fuel Pump (FP) Relay -J17- Short circuit to B+
P1505
Idling Switch -F60 Does Not Close/Open Circuit
P1506
Closed Thottle Position (CTP) Switch -F60- Does Not Open/Short Circuit to Ground (GND)
P1517
Main Relay =>-J271 Electrical Fault in Circuit
P1519
A' Camshaft Position Actuator Circuit Bank 1 Malfunction
P1522
A' Camshaft Position Actuator Circuit Bank 2 Malfunction
P1541
Fuel Pump Relay -J17 Open Circuit
P1542
Angle Sender 1 for Throttle Valve Drive -G187 Implausible Signal
P1543
Angle Sender 1 for Throttle Valve Drive -G187 Signal Too Low
P1544
Angle Sender 1 for Throttle Valve Drive -G187 Signal Too High
P1545
Throttle Valve Control System Malfunction
P1546
Turbo/Super Charger Wastegate Solenoid (A) High Input/Short to B+
P1549
Turbo/Super Charger Wastegate Solenoid (A) Open/Short Circuit to Ground
P1556
Turbo/Super Charger Boost Sensor (A) Circuit Control Limit Not Reached
P1557
Turbo/Super Charger Overboost Condition Control Limit Exceeded
P1558
Throttle Valve Drive -G186 Electrical Fault in Circuit
P1559
Throttle Valve Control Part -J338- Fault in Basic Settings
P1560
P1562
Quantity Adjuster -N146 Upper Limit Stop Value
P1563
Quantity Adjuster -N146 Lower Limit Stop Value
P1565
Throttle Valve Control Part -J338- Lower Stop Not Reached
P1568
Throttle Valve Control Module -J338- Mechanical Malfunction
P1580
Throttle Valve Drive - Bank 1 Malfunction
P1582
Idling Speed Regulation Adaptation Limit Reached
P1592
Height Sensor/Charge Pressure Sensor Unplausible Ratio
P1603
P1604
P160C
Coolant Pump2 Control Circuit Open
P160E
Coolant Pump 2 Control Circuit Low
P160F
Coolant Pump 2 Control Circuit High
P1611
Request MIL on Short Circuit to Ground (GND)
P1612
Engine Control Unit Incorrect Coding
P1613
Request MIL on Open Circuit/Short Circuit to B+
P1618
Glow Plug Relay -J52- Short Circuit to B+
P1619
Glow Plug Relay -J52- Open Circuit/Short Circuit to Ground (GND)
P1625
Data-Bus-Drivetrain Implausible Message From Transmission Control Module
P1626
Data-Bus-Drivetrain Missing Message From Transmission Control Module
P1629
Data-Bus-Drivetrain Missing Message From ADC Control Module
P1630
Throttle/Pedal Position Sensor/Switch -C- Circuit Low
P1631
Throttle/Pedal Position Sensor/Switch -C- Circuit High
P1632
Throttle/Pedal Position Sensor/Switch -C- Circuit Voltage Supply
P1633
Accelerator Pedal Position Sender 2 -G185 Signal Too Low
P1634
Accelerator Pedal Position Sender 2 -G185 Signal Too High
P1639
P1640
P1647
Checking Coding/Versions of Control Modules in CAN-Bus
P1648
Data-Bus-Driving Gear Faulty
P1649
Data-Bus-Drivetrain Missing Message From ABS Control Module
P1650
Data-Bus-Drivetrain Missing Message From Instrument Cluster
P1673
Speed Signal Malfunction Message Fom ABS Control Module
P1681
Control Unit Programming Programming Not Finished
P1702
Malfunction Cannot Activate Envisioned Replacement Function, Since Another Malfunction With Equal Pritority is Present
P1745
Voltage Supply for Solenoid Valves Short Circuit to B+
P1746
Supply Voltage for Solenoid Valves
P1747
Voltage supply for solenoid valves Open circuit/short circuit to Ground (GND)
P1748
P1750
System Voltage Low Voltage
P1751
System Voltage High Voltage
P1778
Valve 7 Electrical Fault in Circuit
P1780
Torque Withdrawal Faulty
P1813
Pressure Control Valve 1 -N215 Electrical Fault in Circuit
P1814
Pressure Control Valve -1- for Auto. Transmission -N215- Open Circuit/Short Circuit to Ground (GND)
P1815
Pressure Control Valve -1- for Auto. Transmission -N215- Short Circuit to B+
P1818
Pressure Control Valve 2 -N216 Electrical Fault in Circuit
P1819
Pressure Control Valve -2- for Auto. Transmission -N216- Open Circuit/Short Circuit to Ground (GND)
P1820
Pressure Control Valve -2- for Auto. Transmission -N216- Short Circuit to B+
P1823
Pressure Control Valve 3 -N217 Electrical Fault in Circuit
P1824
Pressure Control Valve -3- for Auto. Transmission -N217- Open Circuit/Short Circuit to Ground (GND)
P1825
Pressure Control Valve -3- for Auto. Transmission -N217- Short Circuit to B+
P1828
Pressure Control Valve 4 -N218 Electrical Fault in Circuit
P1829
Pressure Control Valve -4- for Auto. Transmission -N218- Open Circuit/Short Circuit to Ground (GND)
P1830
Pressure Control Valve -4- for Auto. Transmission -N218- Short Circuit to B+
P1841
Engine control module/Transmission Control Module (TCM)
Versions not compatible
P1850
Data-Bus-Drivetrain Missing Message From Engine Control Module
P1854
Data-Bus-Driving Fear Hardware Faulty
P1855
Data-Bus-Driving Gear Software Version Monitoring
P1857
Load Signal Fault Signal From Engine Control Unit
P1861
Throttle Position (TP) Sensor -G79-
Malfunction Indication From Engine Control Module (ECM)
P1866
Data-Bus-Driving Fear Missing Messages
P1924
Control Module Pin Coding Unplausible Signal
P1953
Turbocharger (TC) Control Module 2 Faulty
P1954
Automatic Glow Time Control Module 2, Electrical Circuit Electrical Malfunction Electrical Circuit
P1955
Glow Plug Control Module 2 to PCM Comm. Circuit Range/Performance
P2004
Intake Manifold Runner Control Stuck Open
P2008
Intake Manifold Runner Control Circuit/Open, Bank 1
P2014
Intake Manifold Runner Position Sensor/Switch Circuit, Bank 1
P2015
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance, Bank 1
P2016
Intake Manifold Runner Position Sensor/Switch Circuit Low, Bank 1
P2088
A Camshaft Position Actuator Control Circuit Low, Bank 1
P2089
A Camshaft Position Actuator Control Circuit High, Bank 1
P2090
B Camshaft Position Actuator Control Circuit Low, Bank 1
P2091
B Camshaft Position Actuator Control Circuit High, Bank 1
P2092
A Camshaft Position Actuator Control Circuit Low, Bank 2
P2093
A Camshaft Position Actuator Control Circuit High, Bank 2
P2094
B Camshaft Position Actuator Control Circuit Low, Bank 2
P2095
B Camshaft Position Actuator Control Circuit High, Bank 2
P2096
Post Catalyst Fuel Trim System Too Lean Bank 1
P2097
Post Catalyst Fuel Trim System Too Rich Bank 1
P2098
Post Catalyst Fuel Trim System Too Lean Bank 2
P2099
Post Catalyst Fuel Trim System Too Rich Bank 2
P2100
Throttle Actuator Control Motor Circuit/Open
P2101
Throttle Actuator Control Motor Circuit Range/Performance
P2102
Throttle Actuator Control Motor Circuit Low
P2103
Throttle Actuator Control Motor Circuit High
P2106
Throttle Actuator Control System - Forced Limited Power
P2108
Throttle Actuator Control Module Performance
P2110
Throttle Actuator Control System - Forced Limited RPM
P2122
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2123
Throttle/Pedal Position Sensor/Switch "D" Circuit High
P2127
Throttle/Pedal Position Sensor/Switch "E" Circuit Low
P2128
Throttle/Pedal Position Sensor/Switch "E" Circuit High
P2133
Throttle/Pedal Position Sensor/Switch "F" Circuit High
P2138
Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation
P2146
Fuel Injector Group "A" Supply Voltage Circuit/Open
P2149
Fuel Injector Group "B" Supply Voltage Circuit/Open
P2152
Fuel Injector Group "C" Supply Voltage Circuit/Open
P2177
System Too Lean Off Idle, Bank 1
P2178
System Too Rich Off Idle, Bank 1
P2179
System Too Lean Off Idle, Bank 2
P2180
System Too Rich Off Idle, Bank 2
P2181
Cooling System Performance
P2184
Engine Coolant Temperature Sensor 2 Circuit Low
P2185
Engine Coolant Temperature Sensor 2 Circuit High
P2187
System Too Lean at Idle, Bank 1
P2188
System Too Rich at Idle, Bank 1
P2189
P2190
P2191
System Too Lean at Higher Load, Bank 1
P2192
System Too Rich at Higher Load, Bank 1
P2193
System Too Lean at Higher Load, Bank 2
P2194
System Too Rich at Higher Load, Bank 2
P2195
O2 Sensor Signal Biased/Stuck Lean, Bank 1 Sensor 1
P2196
O2 Sensor Signal Biased/Stuck Rich, Bank 1 Sensor 1
P2197
P2198
O2 Sensor Signal Biased/Stuck Rich, Bank 2 Sensor 1
P2199
Intake Air Temperature Sensor 1/ 2 Correlation
P2231
O2 Sensor Signal Circuit Shorted to Heater Circuit, Bank 1 Sensor 1
P2234
O2 Sensor Signal Circuit Shorted to Heater Circuit, Bank 2 Sensor 1
P2237
O2 Sensor Positive Current Control Circuit/Open, Bank 1 Sensor 1
P2238
O2 Sensor Positive Current Control Circuit Low
P2239
O2 Sensor Positive Current Control Circuit High
P2240
O2 Sensor Positive Current Control Circuit/Open, Bank 2 Sensor 1
P2241
P2242
P2243
O2 Sensor Reference Voltage Circuit/Open, Bank 1 Sensor 1
P2245
O2 Sensor Reference Voltage Circuit Low
P2246
O2 Sensor Reference Voltage Circuit High
P2247
O2 Sensor Reference Voltage Circuit/Open, Bank 2 Sensor 1
P2249
P2250
P2251
O2 Sensor Negative Current Control Circuit/Open, Bank 1 Sensor 1
P2252
O2 Sensor Negative Current Control Circuit Low
P2253
O2 Sensor Negative Current Control Circuit High
P2254
O2 Sensor Negative Current Control Circuit/Open, Bank 2 Sensor 1
P2255
P2256
P2257
Secondary Air Injection System Control "A" Circuit Low
P2258
Secondary Air Injection System Control "A" Circuit High
P2263
Turbocharger/Supercharger Boost System Performance
P2270
O2 Sensor Signal Stuck Lean, Bank 1 Sensor 2
P2271
O2 Sensor Signal Stuck Rich, Bank 1 Sensor 2
P2272
P2273
P2274
O2 Sensor Signal Stuck Lean, Bank 1 Sensor 3
P2275
O2 Sensor Signal Stuck Rich, Bank 1 Sensor 3
P2279
Intake Air System Leak
P2293
Fuel Pressure Regulator 2 Performance
P2294
Fuel Pressure Regulator 2 Control Circuit
P2295
Fuel Pressure Regulator 2 Control Circuit Low
P2296
Fuel Pressure Regulator 2 Control Circuit High
P2300
Ignition Coil "A" Primary Control Circuit Low
P2301
Ignition Coil "A" Primary Control Circuit High
P2303
Ignition Coil "B" Primary Control Circuit Low
P2304
Ignition Coil "B" Primary Control Circuit High
P2306
Ignition Coil "C" Primary Control Circuit Low
P2307
Ignition Coil "C" Primary Control Circuit High
P2309
Ignition Coil "D" Primary Control Circuit Low
P2310
Ignition Coil "D" Primary Control Circuit High
P2312
Ignition Coil "E" Primary Control Circuit Low
P2313
Ignition Coil "E" Primary Control Circuit High
P2315
Ignition Coil "F" Primary Control Circuit Low
P2316
Ignition Coil "F" Primary Control Circuit High
P2400
Evaporative Emission System Leak Detection Pump Control Circuit/Open
P2401
Evaporative Emission System Leak Detection Pump Control Circuit Low
P2402
Evaporative Emission System Leak Detection Pump Control Circuit High
P2403
Evaporative Emission System Leak Detection Pump Sense Circuit/Open
P2404
Evaporative Emission System Leak Detection Pump Sense Circuit Range/Performance
P2413
Exhaust Gas Recirculation System Performance
P2414
O2 Sensor Exhaust Sample Error, Bank 1 Sensor 1
P2415
O2 Sensor Exhaust Sample Error, Bank 2 Sensor 1
P2416
O2 Sensor Signals Swapped, Bank 1 Sensor 2/Bank 1 Sensor 3
P2422
Evaporative Emission System Vent Valve Stuck Closed
P2425
Exhaust Gas Recirculation Cooling Valve Control Circuit/Open
P2426
Exhaust Gas Recirculation Cooling Valve Control Circuit Low
P2427
Exhaust Gas Recirculation Cooling Valve Control Circuit High
P2539
Low Pressure Fuel System Sensor Circuit
P2540
Low Pressure Fuel System Sensor Circuit Range/Performance
P2541
Low Pressure Fuel System Sensor Circuit Low
P2564
Turbocharger Boost Control Position Sensor "A" Circuit Low
P2565
Turbocharger Boost Control Position Sensor "A" Circuit High
P2600
Coolant Pump Control Circuit/Open
P2602
Coolant Pump Control Circuit Low
P2603
Coolant Pump Control Circuit High
P2626
O2 Sensor Pumping Current Trim Circuit/Open, Bank 1 Sensor 1
P2629
P2632
Fuel Pump "B" Control Circuit /Open
P2634
Fuel Pump "B" Control Circuit High
P2637
Torque Management Feedback Signal "A"
P2714
Pressure Control Solenoid "D" Performance/Stuck Off
P2715
Pressure Control Solenoid "D" Stuck On
P2716
Pressure Control Solenoid "D" Electrical
P2717
Pressure Control Solenoid "D" Intermittent
P2723
Pressure Control Solenoid "E" Performance/Stuck Off
P2724
Pressure Control Solenoid "E" Stuck On
P2725
Pressure Control Solenoid "E" Electrical
P2726
Pressure Control Solenoid "E" Intermittent
P2732
Pressure Control Solenoid "F" Performance/Stuck Off
P2733
Pressure Control Solenoid "F" Stuck On
P2734
Pressure Control Solenoid "F" Electrical
P2735
Pressure Control Solenoid "F" Intermittent
P3000
Glow Plug Indictor Light -K29- Malfunction Message From Instrument Cluster
P3011
Fuel Pump (FP) 2 Relay -J49- Short Circuit to B+
P3012
Fuel Pump (FP) 2 Relay -J49- Open Circuit/Short Circuit to Ground (GND)
P3025
Angle Sensor 1 (on Throttle Drive 2 Power Accelerator Actuation) -G297- Unplausible Signal
P3026
Angle Sensor 1 (on Throttle Drive 2 Power Accelerator Actuation) -G297- Signal Too Small
P3027
Angle Sensor 1 (on Throttle Drive 2 Power Accelerator Actuation) -G297- Signal Too Large
P3028
Angle Sensor 2 (on Throttle Drive 2 Power Accelerator Actuation) -G298- Unplausible Signal
P3029
Angle Sensor 2 (on Throttle Drive 2 Power Accelerator Actuation) -G298- Signal Too Small
P3030
Angle Sensor 2 (on Throttle Drive 2 Power Accelerator Actuation) -G298- Signal Too Large
P3031
Throttle Drive 2 (Power Accelerator Actuation) -G296- Electrical Malfunction in Circuit
P3032
Throttle Valve Control Module 2 -J544-
Malfunction in Basic Setting
P3033
Intake Air Temperature (IAT) Sensor 2 -G299- Signal Too Small
P3034
Intake Air Temperature (IAT) Sensor 2 -G299- Signal Too Large
P3035
Throttle Valve Control Module 2 -J544- Mechanical Malfunction
P3038
Throttle Valve Control Module 2 -J544- Lower Impact Is Not Being Reached
P3047
Activation Starter Relay 2 Short Circuit to B+
P3048
Activation Starter Relay 2 Short Circuit to Ground (GND)
P3049
Activation Starter Relay 2 Open Circuit
P3057
Exhaust Pressure Sensor 2 High
P3058
Exhaust Gas Recirc.Flow 2 Insufficient Detected
P3059
Exhaust Gas Recirc.Flow Excessive Detected
P3060
Cooling Bypass Valve, Exhaust Gas Recirculation Flow
Electrical
P3061
Cooling Bypass Valve 2, Exhaust Gas Recirculation Flow
Electrical
P3062
P3063
Turbo/Super Charger Underboost
P3081
Engine Temperature Too Low
P3130
Exhaust Gas Recirculation (EGR) System Control Limit Exceeded
P3131
Exhaust Gas Recirculation (EGR) System Lowest Control Limit Exceeded
P3144
Exhaust-Bank 3, Sensor 1, Oxygen Sensor Signal Implausibly Lean
P3145
Exhaust-Bank 3, Sensor 1, Oxygen Sensor Signal Implausibly Rich
P3146
Exhaust-Bank 4, Sensor 1, Oxygen Sensor Signal Implausibly Lean
P3147
Exhaust-Bank 4, Sensor 1, Oxygen Sensor Signal Implausibly Rich
P3148
Exhaust-Bank 3, Oxygen Sensor Before Cat, Heater Circuit Regulation at Upper Impact
P3149
Exhaust-Bank 3, Oxygen Sensor Before Cat, Heater Circuit Regulation at Lower Impact
P3150
Exhaust-Bank 4, Oxygen Sensor Before Cat, Heater Circuit Regulation at Upper Impact
P3151
Exhaust-Bank 4, Oxygen Sensor Before Cat, Heater Circuit Regulation at Lower Impact
P3152
Exhaust-Bank 3, Sensor 1 Inner Resistance Implausible
P3153
Exhaust-Bank 4, Sensor 1 Inner Resistance Implausible
P3175
Exhaust-Bank 3, Mixture Adaptation Range 3
P3176
Exhaust-Bank 3, Mixture Adaptation Range 3 Rich Limit Exceeded
P3177
Exhaust-Bank 4, Mixture Adaptation Range 3 Lean Limit Not Reached
P3178
Exhaust-Bank 4, Mixture Adaptation Range 3 Rich Limit Exceeded
P3200
Emissions-Bank 3 Sensor1, Heater Circuit Short Circuit to Ground (GND)
P3201
Emissions-Bank 3 Sensor 1, Heater Circuit Short Circuit to B+
P3202
Emissions-Bank 3 Sensor 1, Heater Circuit Open Circuit
P3207
Emissions-Bank 3 Sensor 1, Electrical Malfunction in Circuit
P3208
Emissions-Bank 3 Sensor 1, No Activity
P3209
Emissions-Bank 3 Sensor 1, Signal Too Slow
P3211
Exhaust-Bank 1 Sensor 1, Heater Return Connection
P3212
Exhaust-Bank 2 Sensor 1, Heater Return Connection
P3213
Exhaust-Bank 3 Sensor 1, Heater Return Connection
P3214
Exhaust-Bank 4 Sensor 1, Heater Return Connection
P3215
Emissions-Bank 3 Sensor 2, Heater Circuit Short Circuit to Ground (GND)
P3216
Emissions-Bank 3 Sensor 2, Heater Circuit Short Circuit to B+
P3217
Emissions-Bank 3 Sensor 2, Heater Circuit Open Circuit
P3218
Emissions-Bank 3 Sensor 2, Heater Circuit Electrical Malfunction
P3220
Emissions-Bank 3 Sensor 2, Voltage Too Low
P3221
Emissions-Bank 3 Sensor 2, Voltage Too High
P3222
Emissions-Bank 3 Sensor 2, Electrical Malfunction in Circuit
P3223
Emissions-Bank 3 Sensor 2, No activity
P3224
Emissions-Bank 3 Sensor 2, Signal Too Slow
P3225
Exhaust-Bank 3, O2 Correction Behind Catalyst, B1 Limit Attained
P3226
Exhaust-Bank 4, O2 Correction Behind Catalyst, B1 Limit Attained
P3230
Emissions-Bank 4 Sensor 1, Heater Circuit Short Circuit to Ground (GND)
P3231
Emissions-Bank 4 Sensor 1, Heater Circuit Short Circuit to B+
P3232
Emissions-Bank 4 Sensor 1, Heater Circuit Open Circuit
P3237
Emissions-Bank 4 Sensor 1, Electrical Malfunction in Circuit
P3238
Emissions-Bank 4 Sensor 1, No Activity
P3239
Emissions-Bank 4 Sensor 1, Signal Too Slow
P3245
Emissions-Bank 4 Sensor 2, Heater Circuit Short Circuit to Ground (GND)
P3246
Emissions-Bank 4 Sensor 2, Heater Circuit Short Circuit to B+
P3247
Emissions-Bank 4 Sensor 2, Heater Circuit Open Circuit
P3248
Emissions-Bank 4 Sensor 2, Heater Circuit Electrical Malfunction
P3250
Emissions-Bank 4 Sensor 2, Voltage Too Low
P3251
Emissions-Bank 4 Sensor 2, Voltage Too High
P3252
Emissions-Bank 4 Sensor 2, Electrical Malfunction in Circuit
P3253
Emissions-Bank 4 Sensor 2, No Activity
P3254
Emissions-Bank 4 Sensor 2, Signal Too Slow
P3261
Exhaust Bank 3/4 Oxygen Sensors Before Catalytic Converter Swapped
P3262
Exhaust Bank 1/2 Oxygen Sensors Behind Catalytic Converter Swapped
P3263
Exhaust Bank 3/4 Oxygen Sensors Behind Catalytic Converter Swapped
P3278
Linear 02 Sensor, Exhaust-Bank 3/Pump Current Open Circuit
P3281
Linear 02 Sensor, Exhaust-Bank 3/Reference Voltage Open Circuit
P3285
Linear 02 Sensor, Exhaust-Bank3/Common Ground Wire Open Circuit
P3288
Linear 02 Sensor, Exhaust-Bank 4/Pump Current Open Circuit
P3291
Linear 02 Sensor, Exhaust-Bank 4/Reference Voltage Open Circuit
P3292
Linear 02 Sensor, Exhaust-Bank 4/Reference Voltage Short Circuit to Ground
P3295
Linear 02 Sensor, Exhaust-Bank 4/Common Ground Wire Open Circuit
P3298
Catalytic Converter System, Exhaust-Bank 3 Effectiveness Too Low
P3299
Catalytic Converter System, Exhaust-Bank 4 Effectiveness Too Low
P3328
Intake Flap Motor 2 Short to B+
P3329
Intake Flap Motor 2 Open/Short to Ground
P3330
Intake Flap Motor 2 No Signal
P3331
Intake Flap Motor 2 Faulty
P3339
Automatic Glow Time Control Relay 2 Electrical Malfunction in Circuit
P3376
Intake Air Temperature Sensor 3 Circuit-G520 Low
P3377
Intake Air Temperature Sensor 3 Circuit-G520 High
U0001
High Speed CAN Communication Bus
U0002
High Speed CAN Communication Bus Performance
U0073
Control Module Communication Bus Off
U0100
Lost Communication With ECM/PCM "A"
U0101
Lost Communication With TCM
U0103
Lost Communication With Gear Shift Module "A"
U0115
Lost Communication With ECM/PCM "B"
U0121
Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0155
Lost Communication With Instrument Panel Cluster (IPC) Control Module
U0302
Software Incompatibility With Transmission Control Module
U0315
Software Incompatibility With Anti-Lock Brake System Control Module
U0402
Invalid Data Received From TCM
U0404
Invalid Data Received From Gear Shift Control Module "A"
U0415
Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
P-Hex Codes
P000A
"A" Camshaft Position Slow Response, Bank 1
P000B
"B" Camshaft Position Slow Response, Bank 1
P000C
"A" Camshaft Position Slow Response, Bank 2
P000D
"B" Camshaft Position Slow Response, Bank 2
P010B
Mass or Volume Air Flow "B" Circuit Range/Performance
P010C
Mass or Volume Air Flow "B" Circuit Low
P010D
Mass or Volume Air Flow "B" Circuit High
P016A
ISO/SAE reserved
P025A
Fuel Pump Module Control Circuit/Open
P025C
Fuel Pump Module Control Circuit Low
P025D
Fuel Pump Module Control Circuit High
P050A
Cold Start Idle Air Control System Performance
P062B
Internal Control Module Fuel Injector Control Performance
P117A
Bank1, Lambda Correction Catalyst Center Control Limit Reached
P117C
Bank3, Oxygen Sensor Correction Behind Cat Lean Control Limit Exceeded
P117D
Bank3, Oxygen Sensor Correction Behind Cat Rich Control Limit Exceeded
P117E
Bank4, Oxygen Sensor Correction Behind Cat Lean Control Limit Exceeded
P117F
Bank4, Oxygen Sensor Correction Behind Cat Rich Control Limit Exceeded
P118A
Bank3-Probe1, Voltage Too Low/Leakage Air
P118B
Bank4-Probe2, Voltage Too Low/Leakage Air
P12A1
Fuel Rail Pressure Sensor Inappropriately Low
P12A2
Fuel Rail Pressure Sensor Inappropriately High
P12A4
Fuel Rail Pump Control Valve Stuck Closed
P160C
P160E
P160F
Благодаря на ///peter за предоставената информация. :notworthy:
16 Ное 2009, 17:01
