Дата и час: 18 Юни 2019, 04:39
Абревиатури използвани от автопроизводителите
Мнение Абревиатури използвани от автопроизводителите
Ето малко информация за повечето абревиатури използвани от автопроизводителите:
4WD - Four Wheel Drive
4WS - Four Wheel Steering
ABC - Active Body Control
ABS - Anti Blockier System
AC - Air Condition
ACC - Active Cruise Control
AGS - Adaptive Gearbox Shift
ALB - Anti Lock Braking
ASC - Automatic Stability Control
ASC+T - Automatic Stability and Traction Control
ASMS - Automatic Stability Management System
ASR - Anti Schlupf Regelung
ATM - Adaptive Transmission Management
AUC - Automatische Umluft Control
AWD - All Wheel Drive
BAS - Brake Assyst
BST - Battery Safety Terminal
CAN - Controller Area Network
CDI - Common-rail Diesel Injection
CFI - Central Fuel Injection
CNG - Compressed Natural Gas
CVT - Continously Variable Transmission
DBC - Dynamic Brake Control
dCi - diesel Commonrail injection (Renault)
DDE - Digital Diesel Electronics
DISA - Differenzierte Sauganlage sistem
DOHC - Double Over Head Camshaft
DME - Digital Motor Electronics
DSA - Dynamic Stability Assistance
DSC - Dynamic Stability Control
DSTC - Dynamic Stability & Traction Control
EBD - Electronic Brakeforce Distribution
EBV - Elektronische Bremskraft Verteilung
ECU - Engine Control Unit
EDC - Electronic Damper Control
EDC - Electronic Diesel Control
EDS - Elektronische Differencialsperre
EFI- Electronic Fuel Injection
EG - European Gas
EGR - Exhaust Gas
EMC - ElectroMagnetic Compatibility
EPS - Electronic Power Steering
ESP - Electronic Stability Program
ETC - Electronic Traction Control
ETS- Electronic Tracion System
EV - Electric Vehicle
FDR - Fahr Dynamik Regelung
FFV - Flexible Fuel Vehicle
FIRE - Fully Integrated Robotized Engine
F.I.R.S.T.- Fully Integrated Road Safety Technology
FPS - Fire Protecting System
GDI - Gasoline Direct Injection (Mitsubishi)
GPS - Global Positioning System
HDC - Hill Descent Control
HDi - High-pressure Direct Injection
HP - Horse Power
HPi - ... ... injection
i, I - Injection
IC - Inflatable Curtain
ICIM - Individual Control Intake Mainfold
IMS - Instant Mobility System
IRD - Intermediate Reduction Drive
ISOFIX - International Standard Organization FIX
ITS - Inflatable Tubular Structure
JTD - uniJet Turbo Diesel
KW - Kilowatt
LSD - Limited Slip Differential
MPI - Multi Point Injection
NGV - Natural Gas Vehicle
OBD - On Board Diagnostic
PDC - Park Distance Control
PES - Poli Elipsoid System
PPD - Passenger Presence Detection
PRS - Programmed Restraint System
SIPS - Side Impact Protection System
SDI - Standard Diesel Injection
SMH - Societe de Microelectronique et d'Horlogerie
SOHC - Single Over HeadCamshaft
Основни съкращения използвани в автомобилната техника
SPI - Single Point Injection
SRS - Supplemental Restraint System
STC - Stability & Traction Control
TC - Traction Control
TCS - Traction Control System
TDI - Turbo Diesel Intercooler
VANOS - Variable Nockenwelle Steuerung
VDC - Vehicle Dynamic Control
VIS - Variable Induction System
VTEC - Variable valve Timing and lift Electronic Control system
VVT-i Variable Valve Timing - intelligent
WHIPS - WHiplash Protection System
WET W - Engineered Tread
GTI - Gran Turismo Injection
CCB(PCCB) - (Porsche) Ceramic Composite Brake - P-то е, защото те първи ги въведоха в производство
VTG - Variable Turbine Geometry
CL - Comfort Luxe
GL - Grand Luxe
GTP - Grand Touring Prototype
GTR - Grand Turismo Racing
CDI - Capacitor discharge ignition
AMG - Aufrecht Melcher Grossaspach
TDS - Turbo Disel Sport
DSG - direct shift gearbox
FSI - Fuel Stratified Injection — a type of gasoline engine made by Volkswagen
Последна промяна steel на 22 Авг 2009, 10:02, променена общо 5 пъти
21 Авг 2009, 13:43
Регистриран на: 22 Авг 2009, 08:31
Мнение Re: Абриватури използвани от автопроизводителите
Не съм запознат с всички изброени абривиатури, но за ABS знам, че е съкращение от Anti-lock Brake System.
Моля пишете на кирилица!
22 Авг 2009, 08:42
Регистриран на: 27 Дек 2009, 13:18
Мнение Re: Абревиатури използвани от автопроизводителите
А, EGR-означава не само "exhaust gas",както си написал колега ами има накрая едно "recirculation",което ще рече система за рециркулация на изгорелите газове с цел намаляне на вредните емисии!Та цялото му наименование е EGR-"exhaust gas recirculation"
А относно-HPi - ... ... injection-мисля че означава High Presure-но не съм сигурен,така че нека не го вписваме за да не твърдим неверни неща!!
С уважение:
Марин
27 Дек 2009, 15:02
Регистриран на: 09 Яну 2013, 10:15
Skype: avtomivka_ekoliulin
TDS -Турбо Дизел Компресор (turbo disel supercharger) Мисля,че така е правилно.
09 Яну 2013, 10:17
